Some Workflows not triggering
aralibeauty
Hi.
I have setup multiple workflows from Woocommerce to Airtable record
Eg. 1) New Order Created > Filter if line item is "abc" > Created record in Airtable for base "abc"
2) New Order Created > Filter if line item is "xyz" > Created record in Airtable for base "xyz"
I have 5-6 products, and I need to send the appropriate data in appropriate Airtable bases on the basis of Line Item(Product purchased)
The workflow triggers for 1 but not the other. Please help me out with this.
Thanks!
aralibeauty
I figured it out. Had to setup different webhooks for each flow. That worked.
I'll definitely hit you up when I need to setup more complex automations.
Thanks!
