Infusionsoft Apply Tag Issue
Status: Closed · Asked by Jake Efstration on · 0 views
Hi @Jake33,
I am unable to access the video shared, through the link you shared.
Anyway, the Duplicate response occurs when a tag has already been added to the contact, and a user is trying to add the same tag to the same contact again. Your workflow is setup correctly, and the automation should work as intended.
mflauta — Reply ·
Hi Jake! Wanting to ask if this is already resolved? If yes, may I know what workaround you have to make it working? This is exactly my problem right now.
